stepbridge Posted September 28, 2009 Report Share Posted September 28, 2009 hi i have just bought a gas gas txt pro 09. it is virtually brand new but there seems to be a pronounced knock when reving every so often and the the clatters a lot when in neutral and released. is this common or can somebody give me some ideas thanks Quote Link to comment Share on other sites More sharing options...
chewy Posted September 28, 2009 Report Share Posted September 28, 2009 might be running a bit weak..think its a mixture screw on that one so its wind it out to let more mixture pass primary jet. clatering clutch basket or primary gear/clutch basket probably normal but will improve if plug gap and mixture is right.. my beta clatters more when g.box oil is" thin".....there's a few thoughts that wont cost a fortune to try Quote Link to comment Share on other sites More sharing options...
benz19 Posted September 28, 2009 Report Share Posted September 28, 2009 does the rattle go when you pull the clutch in? Quote Link to comment Share on other sites More sharing options...
stepbridge Posted September 28, 2009 Author Report Share Posted September 28, 2009 does the rattle go when you pull the clutch in? yes it does Quote Link to comment Share on other sites More sharing options...
benz19 Posted September 28, 2009 Report Share Posted September 28, 2009 then you have nothing to worry about!! Gasgas pros do not have you normal clutch set up. They do not have 6 coil springs in the clutch basket,they have a circular ring of FINGERS like a car cluch,which when they have no presssure on them,ie clutch out,they rattle,as soon as you pull in clutch and put pressure on the Fingers the rattle stops Benz Quote Link to comment Share on other sites More sharing options...
jam Posted September 29, 2009 Report Share Posted September 29, 2009 Mixture screw needs to be 3 - 3 1/4 turns out, may vary slightly, so trial and era! Quote Link to comment Share on other sites More sharing options...
Guest stixnstonesbrokemybones Posted September 29, 2009 Report Share Posted September 29, 2009 Don't adjust anything. This is normal for the Gas gas pro. The noise can be quite pronounced, but stops when you engage the clutch. It's due to the input shaft behind the clutch that rotates to and fro freely about 10 degrees when there is no drive. They all do it. Quote Link to comment Share on other sites More sharing options...
sam12 Posted October 2, 2009 Report Share Posted October 2, 2009 yep its normal my 125 09 does it and so does my dad 250 nothing to worry about Quote Link to comment Share on other sites More sharing options...
