suzukitc120 Posted October 10, 2009 Report Share Posted October 10, 2009 Hello hope you can help me Ive just bought a rev 50 and when the bike is started on choke from cold it fires up and revs like mad so a quick off flick of the choke and the motor dies back down on with the choke and up she revs again so by playing with this you can get it warmed up enough to reset the tick over and be able to ride it. I do have a fantic which does something similar but on a much less dramatic scale. Am I missing something basic, I have checked and the cable is not nipped or the slide isnt sticking I did read that Betas did have a few carb problems was this issue one of them, Im going to have to sort it as its frightening the life out of the lad. many Thanks John Quote Link to comment Share on other sites More sharing options...
gwrev3 Posted October 10, 2009 Report Share Posted October 10, 2009 I don't think the Beta carb problems - ie leaking fuel through - extend down to the 50 & 80cc models. I've had 2 x 250's (2003 & 2006) and did the carb mods on the 2006. I've also had a 2003 50cc and a 2003 80cc for my son - both of which ran rich and ended up spluttering oil through the exhaust pipe which would spit out onto the mud guard and drip down onto the swinging arm from the joint into the silencer. In both cases, I re-packed the silencer, dropped the needle, adjusted the mixture screw, swapped to an Iridium plug and went onto Castrol synthetic 2-stroke oil. This made the motor run much cleaner (and better.) I can't really remember the tick over being a problem though. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 11, 2009 Report Share Posted October 11, 2009 A likely cause would be too much air getting to the motor with the throttle closed (air leaking into motor). Quote Link to comment Share on other sites More sharing options...
copemech Posted October 11, 2009 Report Share Posted October 11, 2009 The small bikes rev like crazy on choke off cold. Then they settle a bit as they warm up. You may have to play tickle with the choke till things get going! Quote Link to comment Share on other sites More sharing options...
big john Posted October 11, 2009 Report Share Posted October 11, 2009 My youngest son had an '06 125 Rev3 and it had a Dellorto carb fitted as standard, it used to rev high on the choke from cold, and as you say I "feathered" the choke lever until it would run without. It's a bit nerve racking to say the least! Big John Quote Link to comment Share on other sites More sharing options...
suzukitc120 Posted October 11, 2009 Author Report Share Posted October 11, 2009 Thanks everyone I was wondering if Id missed a o seal or something we will have to live with it then ,Ill get the lad some ear plugs!! Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 11, 2009 Report Share Posted October 11, 2009 Yeah - my lads Rev 50 did exactly the same, revved it's nuts off on choke. Never did it any harm. Same with the oil leaking out of silencer too. I ran it about 85:1 maybe could have put it nearer 100:1 on synthetic? Quote Link to comment Share on other sites More sharing options...
