fantic 300 pro Posted October 11, 2009 Report Share Posted October 11, 2009 I would like to fit a pair of wider aftermarket foot pegs to my Fantic 300. What are the best available pegs that bolt on without the need to do any major mount modifcations? Thanks, Paul. Quote Link to comment Share on other sites More sharing options...
lee harris Posted October 12, 2009 Report Share Posted October 12, 2009 (edited) I would like to fit a pair of wider aftermarket foot pegs to my Fantic 300. What are the best available pegs that bolt on without the need to do any major mount modifcations? Thanks, Paul. there arnt any...maybe from a rev3 but you stlll need a hacksaw and cant run a spring Edited October 12, 2009 by Lee Harris Quote Link to comment Share on other sites More sharing options...
axulsuv Posted October 16, 2009 Report Share Posted October 16, 2009 (edited) Without cutting the stock peg mount stubs off about all you can do is add some peg extensions to the stock pegd . B&J racing in TN. makes some . http://www.bjracing.com/index.html Poke around there and you'll find them . But the best thing to do is to cut off the stock stubs and weld some modern mounts in your desired position , Then you can use whatever modern peg strikes your fancy . I used Trialscast pegs and mounts on my 240 and am very happy with the results. There is a post here somewhere showing them . New Pegs , Finaly !, Trialcast on a 240 . is the name of the post but I don't know how to link to it ... I found it funny that the 1980 fantic 50 I have came with modern style peg mounts stock ... On a older bike than my 240 ... Glenn Edited October 16, 2009 by axulsuv Quote Link to comment Share on other sites More sharing options...
