manwithtool Posted October 12, 2009 Report Share Posted October 12, 2009 Had a problem with my sons 125 and moving the plug lead around seemed to fix the bike...But after struggling to get it going after a heavy landing we noticed that the green and white earth wire had come out of the black ignition box thing....We poked it back in and amazingly finished the trial. Since then I've managed to grind the casing back and uncover a bit more wire, although I really didn't think it was going to work.....anyway I put loads of solder around the outcrop of wire, then soldered the wir back the the solder blob. Tested it and it worked !! Then smothered it in araldite to waterproof it. Just wondered if anyone else had had the same problem ? Thought it might help someone else. Anyone know how much these things cost ? Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted October 12, 2009 Report Share Posted October 12, 2009 They are about Quote Link to comment Share on other sites More sharing options...
copemech Posted October 13, 2009 Report Share Posted October 13, 2009 Good tip! Quote Link to comment Share on other sites More sharing options...
manwithtool Posted October 31, 2009 Author Report Share Posted October 31, 2009 Well my smug smile has now disappeared !! My son finished the last trial and the bike died....we just thought it had run out of petrol....But I went to start it today and no spark. My wire is still in place so no idea what's gone wrong....Luckily we had just bought a newer 08 Sherco, so swapped ign modules and it started....put the old one back and no joy. I'm guessing running the bike with the earth wire making intermittent contact might have doen some damage ? or something else has failed. Looks like I will be spending Quote Link to comment Share on other sites More sharing options...
copemech Posted November 1, 2009 Report Share Posted November 1, 2009 Well my smug smile has now disappeared !! My son finished the last trial and the bike died....we just thought it had run out of petrol....But I went to start it today and no spark. My wire is still in place so no idea what's gone wrong....Luckily we had just bought a newer 08 Sherco, so swapped ign modules and it started....put the old one back and no joy. I'm guessing running the bike with the earth wire making intermittent contact might have doen some damage ? or something else has failed.Looks like I will be spending Quote Link to comment Share on other sites More sharing options...
manwithtool Posted November 2, 2009 Author Report Share Posted November 2, 2009 Yes I was lucky to be able to test it...Maes life much easier when you can do this sort of thing....still don;t like the idea of buying a new one !! Quote Link to comment Share on other sites More sharing options...
stork955 Posted November 2, 2009 Report Share Posted November 2, 2009 Gday, can you dig out the potting right back to the circuit board and solder a new wire in? It might be a bit of a job, but to save the cost of a new one might be worth it... Cheers, Stork Quote Link to comment Share on other sites More sharing options...
manwithtool Posted November 4, 2009 Author Report Share Posted November 4, 2009 I guess seeing as it's no good to anyone....alot to grind away to uncover anything.....I have to admit I haven't tested to see if there's a break in any of the wires between the unit and the plugs...have to get my finger out this weekend ! Quote Link to comment Share on other sites More sharing options...
