Pegs And Hangers
slogger
Ive just had a quick look over the mid section of my bike (now the front and rear is sorted) and with the exception of the the brake pedal (which is an easy replacement), I have noticed that both pegs/hangers need some work. The RH peg hanger has come away where the piece of the braket that has the hole for the bolt joins the main hanger. Therefore the peg is only being supported by the front part of the bracket. The LH peg sits at a slight downward angle (I would assume thru a mixture of normal wear and the odd impact from the kickstart process). With a new set of hangers and pegs costing the best part of
