shercomike290 Posted October 13, 2009 Report Share Posted October 13, 2009 Hi just wondering are there still issues with the kickstart and engine casing on the 08 mont 4rt. Just bought one, and a bit concerned because a friend of mine has had two 05 monts and both have had the casing crack caused by the kickstart. Hope someone can help . Cheers mike mc. Quote Link to comment Share on other sites More sharing options...
chewy Posted October 13, 2009 Report Share Posted October 13, 2009 It must be to do with how hard you kick em! Had 2 05 4rt's I do remember IF it wouldnt start it wouldnt start by kickin it harder Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted October 13, 2009 Report Share Posted October 13, 2009 This was a problem on the 05's 4RT's, it happened with my dad's old mont where it kicked back & ended up with the casing broke inside, the problem was resolved on the 07 bikes (i think), by using a new camshaft which prevented it from happening. Cheers, Ben. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted October 13, 2009 Report Share Posted October 13, 2009 I think, but could be wrong, that it was a kick back issue and could be resolved by changing the type of an internal casing bolt so that the head of the bolt acted as a stop and not the casing Quote Link to comment Share on other sites More sharing options...
woody Posted October 13, 2009 Report Share Posted October 13, 2009 It isn't necessarily a kickback that caused it. My 05, which I bought new and which came from the factory with the fix, broke without a kickback. On the first 05 models, the bolt that held the kickstart stop plate in place inside the clutch was too soft and the head could break off the bolt. Once this happened the stop plate was no longer fixed in place and the kicksart would return too far. The fix was to fit a high tensile bolt that wouldn't break. Instead, on mine at least, the kickstart constantly returning against its stop must have chipped away at the lug housing the bolt and eventually the bolt just ripped out of its cracked housing causing a bit of a mess, fortunately fixed under warranty with a replacement engine. I'm no engineer but the kickstart stop didn't look a particularly strong design to me when surveying the aftermath. I've no idea what they could do to cure it though as it would mean a redesign, although you don't seem to hear of it happening to bikes later than the 05. Quote Link to comment Share on other sites More sharing options...
shercomike290 Posted October 14, 2009 Author Report Share Posted October 14, 2009 Thanks guys, all helps but as anyone had or here'd of any of these probs on the 08 mont. mike mc. Quote Link to comment Share on other sites More sharing options...
