coxy Posted October 18, 2009 Report Share Posted October 18, 2009 hi im about to change my swingarm bearings and dog bone bearings and was wondering if anyone knows of a place where cheap bearings can be bought from and at what price? also does anyone know the correct swingarm bearing number?? thanks coxy Quote Link to comment Share on other sites More sharing options...
gaz Posted October 18, 2009 Report Share Posted October 18, 2009 the bearing ref should be etched on the side. google brammer. they should be able to get what ever bearings you need. NSK, SKF or FAG are good brands. Quote Link to comment Share on other sites More sharing options...
newwobbler Posted October 18, 2009 Report Share Posted October 18, 2009 i`ve used simply bearing bearings (simplybearing.co.uk) in the past and their service has been very good. Quote Link to comment Share on other sites More sharing options...
coxy Posted October 19, 2009 Author Report Share Posted October 19, 2009 ive taken the bearing out and i have cleaned up the bearing as good as possible and cannot read the bearing reference number on the swingarm bearings and ive looked on the gguk website and they use the bt or mt bearing number which doesn't help when im using a different source to get these bearings so if anyone knows the correct number for the swingarm bearings actually located in the swingarm then that would be alot of help ive had a look on the simplybearing website and have found them to be quite expensive to the company that i am using so the bearing numbers would be of much help thanks coxy Quote Link to comment Share on other sites More sharing options...
richt Posted October 19, 2009 Report Share Posted October 19, 2009 If you have removed a bearing no point putting it back so now's the best time to replace it. Ask your dealer to get you a kit from AllBalls racing they do them for just about every bike bearings, bushes and seals all included, I have found them to be well priced and they have done the searching for you Quote Link to comment Share on other sites More sharing options...
manx2day Posted October 20, 2009 Report Share Posted October 20, 2009 Yeah, go through your dealer and get AllBalls Racing. Very reasonably priced and they seem to be a popular choice. Quote Link to comment Share on other sites More sharing options...
b40rt Posted October 20, 2009 Report Share Posted October 20, 2009 Or go to your local bearing shop and they will measure it for you from your sample. Quote Link to comment Share on other sites More sharing options...
gaz Posted October 20, 2009 Report Share Posted October 20, 2009 (edited) i agree with b40rt. they'l measure it up and give you the ref. probably be uber cheap from a local bearing place. there is a brammers in scunny too. found it on yell. Edited October 20, 2009 by gaz Quote Link to comment Share on other sites More sharing options...
