g520 Posted November 29, 2009 Report Share Posted November 29, 2009 Masso, this is the sump plug paulmac and Godzilla are talking about in this thread. It is made out of soft material. It Quote Link to comment Share on other sites More sharing options...
bigmike1961 Posted November 29, 2009 Report Share Posted November 29, 2009 That is one nasty looking sump plug, Mine was tight, started to round off, I hammered a socket on and managed to remove the plug. squeezed together chocolate wrapper has more structural integrity than the material that sump plug is made of. Replaced it with a Hell team one - good kit. took about a week to arrive from Australia. Quote Link to comment Share on other sites More sharing options...
paulmac Posted November 29, 2009 Report Share Posted November 29, 2009 Masso said: yikes!....and yours is an 06!!..you'd think a newer bike wood come off easier....what exactly is this plug ??? Yo Masso I've sent you an email - that is THE drain plug Paul MAc Quote Link to comment Share on other sites More sharing options...
masso Posted November 30, 2009 Report Share Posted November 30, 2009 G520 said: Masso, this is the sump plug paulmac and Godzilla are talking about in this thread. It is made out of soft material. It Quote Link to comment Share on other sites More sharing options...
g520 Posted November 30, 2009 Report Share Posted November 30, 2009 (edited) Masso said: yikes!....is this some kinda jap revenge ...stupid material for such a part!....how did you ever figure out the ninja 250 thingy?you could forget it and just use the drain plug under the shifter ....its easier Masso, I had a 250 Ninja parts engine lying in the garage, so I checked. Unfortunately you have to remove the sump plug. The drain plug under the shifter is not enough. I removed it, and laid the bike on its side for maybe 24 hours. Only got a little oil out… Btw, where is salt-spring island? Edited November 30, 2009 by G520 Quote Link to comment Share on other sites More sharing options...
masso Posted December 1, 2009 Report Share Posted December 1, 2009 G520 said: Masso, I had a 250 Ninja parts engine lying in the garage, so I checked.Unfortunately you have to remove the sump plug. The drain plug under the shifter is not enough. I removed it, and laid the bike on its side for maybe 24 hours. Only got a little oil out Quote Link to comment Share on other sites More sharing options...
g520 Posted December 3, 2009 Report Share Posted December 3, 2009 Masso said: dude...saltspring is in trials heaven!.....west coast of canada near vancouver....lots of sinle track forest riding ....masso Interesting, thanks. I took a look in google earth. Seems like a really beautiful place. Maybe I will take a look sometimes, when I visit my sister in Vancouver.. Sorry to wander offtopic, I will keep focused from now on.. Quote Link to comment Share on other sites More sharing options...
masso Posted December 3, 2009 Report Share Posted December 3, 2009 G520 said: Interesting, thanks. I took a look in google earth. Seems like a really beautiful place. Maybe I will take a look sometimes, when I visit my sister in Vancouver.. Sorry to wander offtopic, I will keep focused from now on.. now, you gotta admit...google earth is some kinda wonderful!.........hey, I think I'll go over to paris today, have a look around, no. I'll go to mems and check out the scorpa factory! Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted December 22, 2009 Author Report Share Posted December 22, 2009 Hi all. I have just finally got round to changing the gear oil and hey presto.......rounded the plug off ! Armed with the info supplied on here I set about removing the sump guard, and found myself a good six point socket (12mm I think). I reached around the bike (yes I gave it a reach around) so as to pull the ratchet and socket upto the bolt head. One slight careful bit of a turn later and I'm shaking my head in disbelief... The bolt head had nowhere to bend in my six point socket, there is no way it could round off. How wrong was I. Anyway, better luck tomorrow I hope. Does anybody know what thread the plug is cos I might just drill it out. and re-tap. Quote Link to comment Share on other sites More sharing options...
masso Posted December 22, 2009 Report Share Posted December 22, 2009 houseape1000 said: Hi all. I have just finally got round to changing the gear oil and hey presto.......rounded the plug off !Armed with the info supplied on here I set about removing the sump guard, and found myself a good six point socket (12mm I think). I reached around the bike (yes I gave it a reach around) so as to pull the ratchet and socket upto the bolt head. One slight careful bit of a turn later and I'm shaking my head in disbelief... The bolt head had nowhere to bend in my six point socket, there is no way it could round off. How wrong was I. Anyway, better luck tomorrow I hope. Does anybody know what thread the plug is cos I might just drill it out. and re-tap. WHAT ABOUT VISE GRIPS? well, you can still drain your oil using the drain bolt on side under the shifter[one with copper washer] Quote Link to comment Share on other sites More sharing options...
john b Posted December 22, 2009 Report Share Posted December 22, 2009 Hi had the same on my 05 250. I hammered a slightly smaller socket on,and used an impact driver - it came off no problem. I then replaced with an aftermarket from birketts and had no further problems ! Cheers John Quote Link to comment Share on other sites More sharing options...
montman Posted December 23, 2009 Report Share Posted December 23, 2009 Same problem on my 05 first time I needed it out. Used a chisel punch to turn it out and bought a standard inexpensive bolt/screw from local fastener company, cut to length and been fine ever since. Quote Link to comment Share on other sites More sharing options...
g520 Posted December 23, 2009 Report Share Posted December 23, 2009 houseape1000 said: Hi all. I have just finally got round to changing the gear oil and hey presto.......rounded the plug off !Armed with the info supplied on here I set about removing the sump guard, and found myself a good six point socket (12mm I think). I reached around the bike (yes I gave it a reach around) so as to pull the ratchet and socket upto the bolt head. One slight careful bit of a turn later and I'm shaking my head in disbelief... The bolt head had nowhere to bend in my six point socket, there is no way it could round off. How wrong was I. Anyway, better luck tomorrow I hope. Does anybody know what thread the plug is cos I might just drill it out. and re-tap. Please don Quote Link to comment Share on other sites More sharing options...
houseape1000 Posted December 23, 2009 Author Report Share Posted December 23, 2009 Why has nobody suggested taking the clutch cover off ? It would only take a minute and easy to do, or is there another problem that I don't yet know about ? I tried the chisel, then the vise-grips and no joy.......I usually like a challenge but could do without this one. Its 1-0 to the sump plug. Quote Link to comment Share on other sites More sharing options...
pete_scorpa3 Posted December 23, 2009 Report Share Posted December 23, 2009 The original sump plug is M12 x 1.5 x 12mm Quote Link to comment Share on other sites More sharing options...
