44wilky44 Posted November 4, 2009 Report Share Posted November 4, 2009 just done a top end re-build on mont 315r, (got the bike broke) it now runs but the clutch dosent work, not that familer with bleeding, read a few thing on here and watched a few vids on you tube, but when i look at the clutch slave cylinder part thers no oil bleeder on top ? is this normal? can i remove it and replace it easly, then bleed from bottom up thanks lee Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted November 4, 2009 Author Report Share Posted November 4, 2009 not the best speller ***clutch**** Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted November 5, 2009 Author Report Share Posted November 5, 2009 after removing clutch slave cylinder assembey and hold the piston and press the clutch it moves about 1-2mm how much should it move thanks lee cant find nothing on a search Quote Link to comment Share on other sites More sharing options...
tt5th Posted November 5, 2009 Report Share Posted November 5, 2009 In the manual linked to here - Link... Section 4-11 shows the slave cylinder with what looks like a bleed nipple so not sure why your's hasn't got one... I would double check on my bike but its cold out! Will have a check tomorrow. I guess if you haven't got one, you need a nipple! I've not bled the clutch on mine yet so I'm not sure how it'd go. Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted November 5, 2009 Author Report Share Posted November 5, 2009 all the pics iv looked at have the nipple on , but if u look at the drawing 4-8 thats what mines like cheers lee Quote Link to comment Share on other sites More sharing options...
tt5th Posted November 6, 2009 Report Share Posted November 6, 2009 Yeah I think you need a nipple! Mine has a nipple. Give Sandifords a call, I reckon you'll be looking about Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted November 7, 2009 Author Report Share Posted November 7, 2009 banjo bolt with nipple, got one sorted from a local garage pick it up tomoro, have some fun bleeding, thanks all cheers lee Quote Link to comment Share on other sites More sharing options...
