vfrpete Posted November 14, 2009 Report Share Posted November 14, 2009 Hi, Can anyone tell me the bearing numbers and seal sizes for the front and rear wheel bearings and the headstock bearing numbers to suit a 1989 Fantic 305. Thanks Quote Link to comment Share on other sites More sharing options...
nzralphy Posted November 14, 2009 Report Share Posted November 14, 2009 Even though i rebuilt one of these 8ish years ago..... i didn't write done the bearing numbers. The wheel bearings will be the bearing number etched into the outer face (sometime it is even on the rubber seal). Knock them out after you have heated the hub and head set and take them into the SKF shop. He'll see you right. Ralphy Quote Link to comment Share on other sites More sharing options...
