caddabs Posted November 16, 2009 Report Share Posted November 16, 2009 Can anybody offer some advice please as i am new to the world of hydraulic clutches. I have a 2000 290 which has some clutch drag. Its fine when its good and warm, but when its just started its a bit of a handful ! I have changed the oil (450ml - what a pain that was!), but that doesnt seem to have helped. Is this usual for a Sherco? Can i adjust it out at the handlebar end? May be a dumb question, but i have never had a hydraulic clutch before and am not sure how to adjust them. Having stuck Mr Jarvis through a hedge trying to find nuetral, i am quite keen to sort it out. many thanks - Caddabs Quote Link to comment Share on other sites More sharing options...
ham2 Posted November 16, 2009 Report Share Posted November 16, 2009 Welcome to the Sherco owners club,use the following recipe only if your clutch sticks when cold (and works well when warmed up): Keep bike in shed or garage overnight to be sure you are starting from cold. Use a full dollop of choke. Add a big handful of clutch. Raise the gear lever 'till you find 5th. Gently rock bike back and forth until the clutch/rear wheel frees up. Select neutral. Release clutch. Use one or two judicious prods of the kick start to fire up the bike. Remove choke from the mix. Voila, your bike should be ready to ride..........but just in case ...don't point it at your car ... my brothers bike climbed up his pickup truck all by itself once . If your clutch still sticks when warm then that's a mechanical fault and requires a bit more info than I can provide. Quote Link to comment Share on other sites More sharing options...
caddabs Posted November 16, 2009 Author Report Share Posted November 16, 2009 Many thanks - i will try that. Nearly put mine through the shed wall yesterday !! Nice one - Cheers Caddabs Quote Link to comment Share on other sites More sharing options...
copemech Posted November 17, 2009 Report Share Posted November 17, 2009 Many thanks - i will try that. Nearly put mine through the shed wall yesterday !! Nice one - Cheers Caddabs Yea, well, if you leave the things set, that happens, called stuck! As the plates are stuck together by the surface friction of the oil and such. A dragging effect after normal release can be the effect of warped plates, and has the bike wanting to creep a lot, even with the clutch fully applied. This may require new plates to correct. A stuck one does not creep at all, as it is directly engaged, and will take you where you point it! Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 17, 2009 Report Share Posted November 17, 2009 Mine's just started doing the sticking thing when hot sometimes, guess a seal kit for the master cylinder is called for Quote Link to comment Share on other sites More sharing options...
heavydabber Posted November 17, 2009 Report Share Posted November 17, 2009 Re your clutch drag prob, it may not even be the hydraulic release mechanism, on my 2001 Sherco a lot of use caused the "ears" on the clutch plates to wear slots in the clutch drum "arms", this stops the plates from separating properly when the clutch is pulled in = drag even when hot. If the slots aren't too deep sometimes you can dress them out with a file, if they're too bad it's a new clutch drum/primary gear set. This prob affects lots of trials bikes ridden on the clutch all the time, hope this helps! Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 18, 2009 Report Share Posted November 18, 2009 Last time I looked the basket & hub looked good, only did bearings & seals about 2 months ago. I did the slave cylinder last year. I know exactly what you mean about notched clutches & seeing as I use the clutch for finding grip etc the lever is hardly ever fully out, constantly amazed as to lack of wear Quote Link to comment Share on other sites More sharing options...
