How To Time An Early 125 (tx250)
rtm
I have a early Fantic 125. (TX250) fitted with what I beleive to be a Dansi Ignition system (its stamped into the flywheel anyway)
There is a proximity switch (magic eye) fitted at 4.30 o'clock externally of the flywheel. It has two lines on it. One I guess would be the Fire mark (spark) and the other would be TDC.
On the flywheel is an arrow which points approximatly (within a degree or so) to a boss (nodule / button / welded blob) on the perimiter of the flywheel which passes the proximity switch as it rotates.
I's say this is the trigger.
Being a logical chap, I'd hazard a guess that this must line up with the second mark as the piston reaches TDC.
But it doesnt.
Its about 30 degrees out - The bike does not run by the way, although it does - fire.
Are my assumptions correct?
Does the flywheel have a key?
How do I adjust it?
Do I need a special Fantic or Dansi flywheel puller?
Anything else?
Hello,
I ride a Fantic 125 TX250 (1977/78) and have an ownersmanual (in Italian).
I can send you 2 pages by personal mail about the Flywheel.
It shed some light about the marks.
You will have to translate or read between the italian lines.
My e-mail is info@@vormtekst.nl (remove 1x @)
Kind regards.
and aries is a VERY nice 125....
I know! He emailed me some photo's today.
Mine on the other hand is about as rough as is possible to achieve yet still be ridable.
Aries.
Thanks for the info, I removed the flywheel to find the key had sheared, hardly suprising as it was all loose.
I set everything according to instuctions and it fired up first kick. Runs like a dream.
many many thanks.
RTM
