montyb Posted November 21, 2009 Report Share Posted November 21, 2009 Hi does anyone out there know how to test a 125 SHERCO CDI unit. Not getting any sparks and suspect this unit. Kill switch plug cap all illiminated and still no sparks. ANY HELP WOULD BE VERY GRATEFUL!!!!! Thanks Montyb. Quote Link to comment Share on other sites More sharing options...
millerme Posted November 21, 2009 Report Share Posted November 21, 2009 hi mate is your coil and cdi all in one if so DO NOT GO TO SHERCO for a new coil/cdi as they will charge you about Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted November 21, 2009 Report Share Posted November 21, 2009 The Ducati coil that millerme mentioned will only fit the early bikes upto sometime in 2002 I think, if yours is blue it will fit, if it's black you will need the Lenonelli one. It's more likely to be the stator plate that has gone, I'd check that first using the diode check mode on a multi meter, you should get reading something like this, don't worry about exact numbers if it is somewhere in the same region. using the red lead to the plug terminals and black to earth. Blue no reading (sometimes shown as 1 or error) brown 1000 to 1600 black 1050 to 1650 using the leads the other way around i.e. black lead to the coloured wires, red to earth. Blue 600 to 730 brown 650 to 770 black 650 to 770 Quote Link to comment Share on other sites More sharing options...
montyb Posted November 21, 2009 Author Report Share Posted November 21, 2009 The Ducati coil that millerme mentioned will only fit the early bikes upto sometime in 2002 I think, if yours is blue it will fit, if it's black you will need the Lenonelli one.It's more likely to be the stator plate that has gone, I'd check that first using the diode check mode on a multi meter, you should get reading something like this, don't worry about exact numbers if it is somewhere in the same region. using the red lead to the plug terminals and black to earth. Blue no reading (sometimes shown as 1 or error) brown 1000 to 1600 black 1050 to 1650 using the leads the other way around i.e. black lead to the coloured wires, red to earth. Blue 600 to 730 brown 650 to 770 black 650 to 770 MANY THANKS VERY GRATEFUL WILL GIVE THAT A GO Quote Link to comment Share on other sites More sharing options...
montyb Posted November 21, 2009 Author Report Share Posted November 21, 2009 The Ducati coil that millerme mentioned will only fit the early bikes upto sometime in 2002 I think, if yours is blue it will fit, if it's black you will need the Lenonelli one.It's more likely to be the stator plate that has gone, I'd check that first using the diode check mode on a multi meter, you should get reading something like this, don't worry about exact numbers if it is somewhere in the same region. using the red lead to the plug terminals and black to earth. Blue no reading (sometimes shown as 1 or error) brown 1000 to 1600 black 1050 to 1650 using the leads the other way around i.e. black lead to the coloured wires, red to earth. Blue 600 to 730 brown 650 to 770 black 650 to 770 MANY THANKS VERY GRATEFUL WILL GIVE IT A GO Quote Link to comment Share on other sites More sharing options...
chrisb583 Posted November 21, 2009 Report Share Posted November 21, 2009 The Ducati coil that millerme mentioned will only fit the early bikes upto sometime in 2002 I think, if yours is blue it will fit, if it's black you will need the Lenonelli one.It's more likely to be the stator plate that has gone, I'd check that first using the diode check mode on a multi meter, you should get reading something like this, don't worry about exact numbers if it is somewhere in the same region. using the red lead to the plug terminals and black to earth. Blue no reading (sometimes shown as 1 or error) brown 1000 to 1600 black 1050 to 1650 using the leads the other way around i.e. black lead to the coloured wires, red to earth. Blue 600 to 730 brown 650 to 770 black 650 to 770 thats a good point but surely its right in working backwards through the problem i.e from the plug etc the lead to the CDI ??? Or is your way from experiance ? just curious ?? Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 22, 2009 Report Share Posted November 22, 2009 Stators always seem to be the weak point & the readings to check are available. Also easiest thing to test Quote Link to comment Share on other sites More sharing options...
misterroy Posted November 5, 2017 Report Share Posted November 5, 2017 On 21/11/2009 at 11:44 PM, chrisb583 said: using the red lead to the plug terminals and black to earth. Blue no reading (sometimes shown as 1 or error) brown 1000 to 1600 black 1050 to 1650 I had a spark this morning, I went a wee spin. Later my friend went out on the bike and he said it was like the fuel had ran out. He gave it a kick, it ran for a bit then it happened again. When we got it home there was no spark. When I did the above test 1800 was the reading I got on both wires. Is this so high that I would get no spark? We went up a stream yesterday, but there was no water or wet look when I took the flywheel cover off. Quote Link to comment Share on other sites More sharing options...
