martyd Posted November 21, 2009 Report Share Posted November 21, 2009 Does anyone have any suggestions how to move the brake padal to the( proper) Right hand side of my B40 Have tried now for 3 months and just cant get onto it in the left What lever /cable set up do you think?? Jackson frame and cub hubs Marty D Quote Link to comment Share on other sites More sharing options...
woody Posted November 21, 2009 Report Share Posted November 21, 2009 Montesa Cota 247 and Ossa MAR both use a spindle attached to a right side pedal which runs behind the engine through bushes in the frame plates by the footrests which then operates a rod or cable on the left side. The Montesa set up is better as it uses an arm attached to the left side of the spindle which is then connected to the brake arm on the wheel by a rod or cable. The Ossa's is a slightly more tortuous affair where the outer cable is used as the actuator rather than the inner cable - definitely not worth copying. I think Sprites have a spindle arrangement too. Quote Link to comment Share on other sites More sharing options...
martyd Posted November 22, 2009 Author Report Share Posted November 22, 2009 Thanks for that info BUT Had a better look today and dont think it can be done when you get the brake pedal in the right position the kickstart fouls it I think ive tied a lot of different pedal shapes but no good Any ideas or pics?Marty D? Quote Link to comment Share on other sites More sharing options...
