scottie_b205 Posted November 22, 2009 Report Share Posted November 22, 2009 Hello, I would like to know if the rear shocks are suppose to be 14 inches long? Also, are they suppose to be mounted in the front mounting hole or the rear. There are two holes for mounting and my shocks which are 14 1/8 inches long are mounted in the rear position. Thanks, Scott Quote Link to comment Share on other sites More sharing options...
pedronicman Posted November 22, 2009 Report Share Posted November 22, 2009 Hi shock length should be 360mm (14 1/4 inches) fron centre to centre Use the forward bottom shock mount only. Quote Link to comment Share on other sites More sharing options...
scottie_b205 Posted November 27, 2009 Author Report Share Posted November 27, 2009 Thanks for the reply. I asked because I wasn't sure if my fox shox could be rebuilt. The shafts have small pitted rust spots. I believe I have found a source for them though. Quote Link to comment Share on other sites More sharing options...
