andy198712 Posted November 23, 2009 Report Share Posted November 23, 2009 Hi all, Just wondering where can i find a rear tube less rim? looking at lacing it to my KTM to have a tubeless rear...... also do you think i'll get away without a rimlock? as there isnt one on my trials bike.... cheers guys Quote Link to comment Share on other sites More sharing options...
woody Posted November 23, 2009 Report Share Posted November 23, 2009 Which tubeless tyre are you thinking of running on a KTM - enduro/motocross tyres are tubed and the tubeless ones they were experimenting with are completely different from trials type. It's usually only the Pirelli MT43 that riders use on enduro bikes and that is tubed. It's a hard enough compund/construction to put up with the abuse an enduro motor will give it. The tubeless trials tyres are modern soft construction and I would think they'd be shredded in minutes on an enduro bike. A rim lock isn't required on tubeless rims and once you've drilled the rim to fit one you're going to have to fit a tube as it will no longer seal.... Quote Link to comment Share on other sites More sharing options...
andy198712 Posted November 23, 2009 Author Report Share Posted November 23, 2009 this is where i'll raise a few eye brows...... my ktm was a 450 exc, now its 540.... but i use X11 rears on it i get partworn cheap.....they actually last well, drift a bit on the road, but never loose grip!!! thats what i thought about a rimlock.... so can any rim be tube less if you install the right tape and seal it well..? or is partly down to the shape and the lip ect? cheers for the reply mate, i havnt really found many places selling just rims... Quote Link to comment Share on other sites More sharing options...
woody Posted November 23, 2009 Report Share Posted November 23, 2009 Michelin x11.... It's easy enough to rip the knobbles off those on a trials bike, never mind a KTM - brave lad.... Anyway, the tubeless rims like that on your Gasser, are about Quote Link to comment Share on other sites More sharing options...
andy198712 Posted November 24, 2009 Author Report Share Posted November 24, 2009 Yeah it does tend to peel off the knobbles, but not till its 2 thirds worn which is good time to change anyway... I prefere them to enduro tyres as they spin up too much. Cheers for the info there, are any makes softer then others? I'll count my spokes tomorro to make sure I get it right but cheers for the heads up there! The rim on my txt270 takes a lot of hits and isn't dented, was quite suprised tbh, but I guess its a light bike too. Once again thanks very much Is it wrong I wanted to anodise the rim before fitting Quote Link to comment Share on other sites More sharing options...
leanin Posted November 24, 2009 Report Share Posted November 24, 2009 I've heard good things about this setup: http://tubeliss.com/ A lot of enduro guys around here use Dunlop 803 trials rear tires on their KTM 530s and love them. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted November 24, 2009 Report Share Posted November 24, 2009 The "tubeliss" thing looks interesting - would be interesting to get some real feed back on a trials bike Quote Link to comment Share on other sites More sharing options...
bigfoot Posted November 24, 2009 Report Share Posted November 24, 2009 For the website "so it holds the tire firmly and makes the sidewalls stay upright and absorb the full impact, unlike bending and deflection you get with conventional tubes." Does this not suggest it doesn't aid grip? It the side wall resists deflection what's the benifit of running low pressures. We could all run zero pressure and use solid rubber tyres. Quote Link to comment Share on other sites More sharing options...
rabie Posted November 24, 2009 Report Share Posted November 24, 2009 when the guys ride the natterejack BEC round (in the sand in Hampshire) they have to use trials tyres, most seam to go for the MT43, although i have herd that guy up north have used Dunlops in hard events, so maybe that's worth trying. most guys have been very dismissive/scare stories of using Michelin and IRC on enduro bikes. They actually get a mousses in them and sometimes pack them with old tubes too! Quote Link to comment Share on other sites More sharing options...
andy198712 Posted November 25, 2009 Author Report Share Posted November 25, 2009 i'm personally not all that convinced by the tubliss things.... Quote Link to comment Share on other sites More sharing options...
