jonnieboy Posted November 24, 2009 Report Share Posted November 24, 2009 hi i have a 99 315 and there is loads of play in front disc / bobbins i have measured them up and they seem all very similar but 1 mm clearance on every hole seems a bit much am i looking at new disc and bobbins thanks Quote Link to comment Share on other sites More sharing options...
wherry Posted November 25, 2009 Report Share Posted November 25, 2009 I was worried about the play on mine when I got it so I bought some new bobbins from BVM. They've helped a bit but there's still quite a bit of play. I've stopped worrying about it because I only notice it if I'm in the garage doing a bit of balance practice - riding I never give it a thought. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted November 25, 2009 Report Share Posted November 25, 2009 Stick some silicon sealant around them before assembly and stops the rattle but allows the float Quote Link to comment Share on other sites More sharing options...
samandkimberly Posted November 25, 2009 Report Share Posted November 25, 2009 Standard play is listed in the owner's manual as .3 to 1 mm, with a service limit of 2mm - a lot. I had mine apart this spring and it looked like the disc wears as much as the bobbins; you may have to replace both if you want to make it quiet. That said the play shouldn't affect the brake performance, if anything too much play is better than none. Sam Quote Link to comment Share on other sites More sharing options...
jonnieboy Posted November 25, 2009 Author Report Share Posted November 25, 2009 thanks for the replies im gonna give the bobbins a go see what that does i had a husaberg supermoto a while ago and that had a lot of play on a berringer disc but i was never as subtle with that brake must spend less time being critical in the garage i think Quote Link to comment Share on other sites More sharing options...
