V-mar Rear Shock Linkage For 4rt
leanin
Got them today, ~2 weeks after ordering; about what I'd expect getting them overseas (I'm in Boston, MA)
The look solid, about 5mm thick; laser cut. Not show bike material, but could be, with a little elbow grease. Unfortunately, it's going to be several days at best until I get to compare then to the stockers and install them.
Sam
I'm 210 lbs and they helped the rear end ride higher, which in turn increased the steering response. The V-mar ones are aluminum and I have seen that after a LOT of use the holes get egg shaped. I bought some stainless steel ones from Lewisport, they're cheaper and more durable. They are milled out in the middle, and a bit thicker as well.
