sam Posted December 14, 2004 Report Share Posted December 14, 2004 (edited) I'm looking for any advice on flushing out the crank case? My buddy toasted his GasGas's top end, we pulled the jug off and then had taken time off from the repair. Well some atifreeze went in the crank case and actually did weird things with the synthetic motor oil, actually froze up! You could see that every thing turned white and hardend, I've poured 2 stroke oil in there and let it soak, then put a socket/breaker bar on the fly wheel nut and loosened it up. Crank spins fine, but I'm wondering what would be a good solution to soak/flush the case? Does Napa have something for this? Do you think we must split the case and do the (bottom end bearing), or just let it soak/flush a few times? sam Edited December 14, 2004 by Sam Quote Link to comment Share on other sites More sharing options...
