yeoblade Posted November 29, 2009 Report Share Posted November 29, 2009 I need to remove the flywheel as there is a problem with the stator or woodruff key( bike wont rev) Having bought the puller tool it won't come off. Do the 2 philips headed screws need to come out first before the flywheel will come off? I have tried to remove these with no success (impact driver etc) If they need to be removed before the flywheel will come off then I will probably need to drill then out !! Any help most appriciated. Quote Link to comment Share on other sites More sharing options...
dan williams Posted November 29, 2009 Report Share Posted November 29, 2009 Once the center nut is off the puller should pop it off. If it's been stuck on there a long time there may be some cold welding (can't remember the proper name) that sticks it on tight. Not trying to be a smartass but you may have to be less of a girly man with the wrench on the puller. Quote Link to comment Share on other sites More sharing options...
malcra Posted November 29, 2009 Report Share Posted November 29, 2009 You may want to hold the flywheel with something (see my recent comment on this) and then give the spanner / socket wrench a sharp tap....this can help. It maybe the flywheel has been lapped in. Quote Link to comment Share on other sites More sharing options...
02-apr Posted November 29, 2009 Report Share Posted November 29, 2009 Once the puller is tensioned you could try a hammer tap on the bolthead of the puller (the blow goes along the line of the puller bolt). Don't have your leg in the way when the flywheel pops off. Quote Link to comment Share on other sites More sharing options...
yeoblade Posted November 29, 2009 Author Report Share Posted November 29, 2009 Ok thanks for the help guys, Off to the NEC bike show tomorrow so will give it another go on tuesday, I was giving the puller a fair bit of torque using two 15" spanners and thought any more and something would bust! Thats why I was concerned about removing the two philips screws first or not, Must try harder Quote Link to comment Share on other sites More sharing options...
yeoblade Posted December 4, 2009 Author Report Share Posted December 4, 2009 That got it off, a bit more muscle power need, Woodruff key ok so took stator off and sent to Westcountry rewinds, was informed the trigger was faulty, repaired and back with me in 2 days, very quick turn round. Problem is IT STILL WONT REV , same problem. Revs to about 2000RPM then stops firing above that, but it seems to run absolutly fine at tick over and up to 2K rpm, Anyone have any other idears have taken carb off and cleaned it and new plug . Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 4, 2009 Report Share Posted December 4, 2009 Gday, check the exhaust front to back and check the airfilter. What colour is the spark plug? Cheers, Stork Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 4, 2009 Report Share Posted December 4, 2009 Gday, does the bike actually cut out or just run badly? If badly - check the exhaust front to back and check the airfilter. What colour is the spark plug? If cutting out - check the plug cap and wiring. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
yeoblade Posted December 4, 2009 Author Report Share Posted December 4, 2009 Engine totally stops firing above about 2K RPM and starts firing again when the revs drop back again. At low revs it runs fine , no misfires, starts fine first time, though will very occasionally kick back. It seems as if the sparks is stopping above a certain rpm though not sure how to test/prove that this is the fault. CDi ?, plug lead........ Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted December 5, 2009 Report Share Posted December 5, 2009 you could always try a spark gap tester thing that you put inline with the ht lead to the plug and check that you have an output from the coil above 2k if not then try a new coil and cdi .. maybe you could borrow one if you know of another bike in the area maybe something is breaking down and it cant fire a spark past a certain point.. ? Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 5, 2009 Report Share Posted December 5, 2009 Gday, it sounds awfully like fuel to me... Blocked main jet perhaps? It seems very unusual to cut out over 2000 or so. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 5, 2009 Report Share Posted December 5, 2009 I had these symptoms on an xt600 years ago, turn out there was a loose bit in the exhaust that moved with the increased pressure. Quote Link to comment Share on other sites More sharing options...
pa. Posted December 5, 2009 Report Share Posted December 5, 2009 Possibly the Fuel Filter, Tank Breather or the Fuel Tap are partially blocked. Lets enough fuel through to allow the bike to run then when more fuel is required it starves for fuel. Had a car once that above 80 kph it would miss and fart around. Mechanic said needs Platinum Plugs. I doubted him saw another mechanic who listened to what I said and went straight for the fuel filter and poured out a heap of rust or dirt. New filter and good as gold. Old mechanic said would still run better with Platinum plugs, I don't use him any more. Quote Link to comment Share on other sites More sharing options...
yeoblade Posted December 5, 2009 Author Report Share Posted December 5, 2009 Thanks for useful tips guys, will strip down fuel system this afternoon, I took a video of the problem and put it up on Youtube, sometimes a picture is woth a thousand words in explaining something ,Any other thoughts after seeing the vid most welcome (already Quote Link to comment Share on other sites More sharing options...
paul w Posted December 5, 2009 Report Share Posted December 5, 2009 i have just watched your video on youtube, not sure what the problem is but for peace of mind and for no cost take the carb off, remove all the jets and give it a good blow out with a high pressure airline. before putting the jets back in blow them all through and comfirm that they are clear visually (hold up to a bright light). check the float heights (see topic on here, well covered). also check the needle, is it seated correctly? is the clip there? then before replacing the carb remove the reed block and make sure they are intact and seated correctly. once you are 100% happy that all this is done refit and try again with a new spark plug, making sure that the plug cap is screwed right onto the HT lead. if this doesnt cure the problem then you will have to look at an electrical component and seeing as you have already tried the winding and trigger it narrows it down a bit. if you lived nearer i would suggest swapping compenents from my bike to see what happened, perhaps someone local may offer to help with this. let me know how you get on Paul Quote Link to comment Share on other sites More sharing options...
