fenny67 Posted November 29, 2009 Report Share Posted November 29, 2009 hi can anybody help been out on my gasgas txt-pro 280-06 after about 1/2 it started to over heat could this be the fan realy or the water pump thanks ian..... Quote Link to comment Share on other sites More sharing options...
Andy Posted November 29, 2009 Report Share Posted November 29, 2009 One topic, one forum please. Cross-posting the same topic to multiple forums is not allowed. This Forum is where you're most likely to get the best response. Quote Link to comment Share on other sites More sharing options...
jordi Posted November 29, 2009 Report Share Posted November 29, 2009 Most likely the thermostat, link it across and check the fan runs when you start the motor. Quote Link to comment Share on other sites More sharing options...
kwakisaki Posted April 28, 2010 Report Share Posted April 28, 2010 put a bit of tipx on the fan so if it dont work it will b in same place .but if it works it will b in a different spot Quote Link to comment Share on other sites More sharing options...
