Rev 3 2000
drop5
my 2000 rev 3 was running very sick back fireing coughing and spluttering.changed the plug no good. cleaned the carb much better but now when using wide throttle openings it miss fires or 4 strokes. When stripping the carb checked the air jet ( looking from filter side this is the small hole at the bottom of the carb inlet) mine is stright thro. The Mikuni VM manual shows a jet, should there be a brass jet or something in there?
