Front Breake In Mud Is Working Badly
bobtlr
Hi Bob, just a thought, are you sure the caliper pistons are allowed to apply the same force as when new? Might there be some muck between the caliper and pads? Are you using never seize between the pad EDGES and the caliper? These would seem a more likely problem than pad material. Good luck
All I can tell is that I have been running the "BRAKING" pads, and they doo seem to work better than the Galfers when wet.
Mind you, these were installed as to minimize the noise issue with the wave rotors(by Braking as well), yet there are tradeoffs is seems.
The Braking pads do seem to be less noisy, and offer improved feel and progression, yet I have yet to find them equal to the Galfers in dry operation when you want that wheel to stop NOW to do a bit of a rear hop and such.
MY finger memory still has a problem with that! :thumbup:
Edited by copemech
