Beta Rev3 Loose Kickstart
dang2407
Hi Folks
I'm a trials newbie and I've just bought a 2004 Rev3. I've noticed that the kickstart is loose on the splines and the washer on the end of it is cracked along the weld. Another bike I saw was exactly like this and the shop said "They're all like that Sir, the washer doesn't do much...".
this doesn't seem right to me as the splines will one day wear out. What is the solution:
1) Leave it as it is
2) Weld the washer back on - won't this affect the hardening of the kickstart body and hence the splines making them even weaker?
3) Buy a new kickstart and spindle
4) Something else...
Any help gratefully appreciated!
I welded the washer back on on 3 rev 3 we had,was still ok after a year use.Splines in theory should be softened by doing this but its better tnan buying a new kickstart which will probably fail in the same way
