oshow Posted December 8, 2009 Report Share Posted December 8, 2009 Hello, I currently have a problem with my 03 Sherco 250 Gearbox. At the moment i can only select 1st & 2nd gear. The gearstick is still in its normal position but has a small bit of up and down movement (approx 3mm). When selecting first gear i can feel some spring tension but when i pull up on the lever and select second gear their is no spring tension and i cannot select 3rd gear. I have ordered a gear selector spring from Splat UK (Part No M110) and will attempt to replace it this weekend. I have not disassembled any part of the engine yet and was hoping to get some advise on the best approach to replacing this spring, if that is the problem of course. Any suggestions will be gratefully accepted. Thanks OShow.... Quote Link to comment Share on other sites More sharing options...
redbull8447 Posted December 8, 2009 Report Share Posted December 8, 2009 Hi m8, i would first take the clutch cover off and remove the clutch, you should then be able to see the gear change mech, look close at everything before striping case's down to remove gears Quote Link to comment Share on other sites More sharing options...
copemech Posted December 9, 2009 Report Share Posted December 9, 2009 (edited) If you have no return from the up position going to 2nd gear, it does sound as though the return spring may be broken. And if it is, you need to retrieve that before further operation as well. Pull the clutch cover and clutch! And be sure to properly scribe the position of the clutch hub retaining nut and shaft so you can put things back easily! Edited December 9, 2009 by copemech Quote Link to comment Share on other sites More sharing options...
oshow Posted December 9, 2009 Author Report Share Posted December 9, 2009 Thanks guys, Will let you know how i get on with the repair. Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted December 9, 2009 Report Share Posted December 9, 2009 A similar thing happened to my sons sherco after catching the gear lever on a rock in a section. It turned out to be the gear selector that is , if I remember correctly , situated behind the clutch basket . It is shaped like a letter ' C ' and what happened was the tip on one side at the end of the letter ' C ' , that turns the selector , broke off therefore only allowing the selector to change up but not down or vice versa whichever side broke off . It was a while ago when this happened so the mechanical side of the story may be slightly wrong but the repair , as I vaguely remember , was straight forward and quite easy as I recall . Hope This Helps Phil Quote Link to comment Share on other sites More sharing options...
copemech Posted December 10, 2009 Report Share Posted December 10, 2009 Yes, Phil is correct in that as well, and that part acts as a sort of ratchet mechanism in the process of rotating the drum. I was not quite going there as yet, but it still needs to be inspected. Inspection should tell! Quote Link to comment Share on other sites More sharing options...
ham2 Posted December 10, 2009 Report Share Posted December 10, 2009 Sometimes ,if you have whacked it, the weld breaks on the lever shaft. Quote Link to comment Share on other sites More sharing options...
