Problem Thread: 1997 Gg Fortuna 270cc
skj0lsvik
Thanks for nice answers!
When I fill my spare-can with gasoline I normally fill it up with 8 litres, then I'll put about 0,4litres of oil in there. I think atleast it was 0,4. Maybe 0,5?
Would this be too much oil?
And yeas, the carb is cleaned :rolleyes:
Which side is the flywheel on(probably a dumb question, but oh well...)?
I am buying a new plug for it, which one would suit the bike best?
And then again, thanks for all the help!
At 50 - 1 it would be 20ml oil per Litre (1000ml)
If Im right, you are putting in about 50ml per litre = 20 - 1. ( based on you putting in 400ml per 8000ml )
Its a wonder it runs at all !
A lot of folk run their bikes on about 60 - 1, which is a bit heavy on the oil, but keeps it well lubed......however, the exhaust will need cleaning regularly.
I run the scorpa at 75/80 - 1 and it is fine.
I don't know what others do, but I mix fuel by the litre, and have a syringe to measure the oil in.
  • 3 weeks later...
Okey, the bike finally starts with new gasoline ++
The exhaust is also cleaned properly, will repack the silencer when I get some minutes to spare.
But it still coughs and won't go right. Damn, starting to get tired of this.
