motofire Posted December 15, 2009 Report Share Posted December 15, 2009 Anyone know of where I can get a stiffer (10% or so) fork spring for an 09 Evo 290? I'm located in the US but would apprciate a lead from anywhere. Thanks..... Quote Link to comment Share on other sites More sharing options...
picktas Posted December 15, 2009 Report Share Posted December 15, 2009 I would just preload the springs slightly - A few coins or washers will make a big difference to the strength of the spring Quote Link to comment Share on other sites More sharing options...
motofire Posted December 15, 2009 Author Report Share Posted December 15, 2009 I would just preload the springs slightly - A few coins or washers will make a big difference to the strength of the spring Thanks for the suggestion but that would only change pre-load. Which affects ride height and initial spring tension not spring rate. Quote Link to comment Share on other sites More sharing options...
liviob Posted December 17, 2009 Report Share Posted December 17, 2009 I had to Install stiffer springs in my 290 suspension to hold up my 250lbs. I had an oppertunity to ride two stock evos back to back with mine. Adding firmer springs makes the suspension feel much plusher while adding bottoming resistance. The stock suspension feels like it has mountain bike rubber bumper springs in the suspension compared to firmer springs. What do you weigh? If you dont think you need a firmer spring for the rear you may be able to raise the fork oil level to increase the bottoming resistance without changing the speed of the compression action in the forks. A few millimeters will make a big change in Mid stroke and bottoming feel. Have you checked to see where the oil level is set now? My oil level was low on both fork legs from the manual specs. Quote Link to comment Share on other sites More sharing options...
motofire Posted December 17, 2009 Author Report Share Posted December 17, 2009 Liviob, I already replaced the rear with a heavier spring. I weigh 220 and cannot even get the sag right. Can you please tell me where you got the spring? You'll make my Christmas! Quote Link to comment Share on other sites More sharing options...
liviob Posted December 17, 2009 Report Share Posted December 17, 2009 (edited) I think can help you. What weight is the rear spring that you have and where did you get it. If you got the spring from Scott Debolt which spring did you get? Edited December 17, 2009 by Liviob Quote Link to comment Share on other sites More sharing options...
motofire Posted December 17, 2009 Author Report Share Posted December 17, 2009 That would be great... Yes I did get the spring from Scott. It's the medium weight spring that goes up to 225#'s. I weigh about 220. Quote Link to comment Share on other sites More sharing options...
liviob Posted December 17, 2009 Report Share Posted December 17, 2009 Did the spring have a number written on the end of the sprng face? If so what was it. How long is the spring with no preload on it and how many turns of preload do you currently have dialed in now. Have you had an oppertunity to remove the fork caps and remove the spring and with the forks collapsed all the way measure from the top of the fork tube to the top of the oil to see where the oil level is currently set. If it's not set to the factory specs, reset it. 120mm spring side and 60mm non spring side 5wt oil. Quote Link to comment Share on other sites More sharing options...
laser1 Posted December 17, 2009 Report Share Posted December 17, 2009 Hey Bob - Did you put a HD spring in the front? If so, where did you aquire it? Quote Link to comment Share on other sites More sharing options...
liviob Posted December 17, 2009 Report Share Posted December 17, 2009 (edited) These fellas made the rear spring. MCR 8106782617. They made me a front .71kg spring to match the heavy rear spring. With the .71kg i cannot dial in any preload because of where i have the rear spring preload set. I have to adjust firmess by adjusting oil height using Redline oil like water. I was able to get the suspension set to work very good but I recomend a .69kg if you weigh as much as me. If you are heavyer than me I will gladly trade you my .71kg for a .69kg as you will be very happy with my .71kg spring. Edited December 17, 2009 by Liviob Quote Link to comment Share on other sites More sharing options...
laser1 Posted December 17, 2009 Report Share Posted December 17, 2009 Thanks for the info Bob - Looks like a good place. Quote Link to comment Share on other sites More sharing options...
motofire Posted December 17, 2009 Author Report Share Posted December 17, 2009 I'm kinda confused now. I just had my stock spring rate checked and it came in at .69. The good news is he gave me a bunch of springs to test with. Quote Link to comment Share on other sites More sharing options...
liviob Posted December 17, 2009 Report Share Posted December 17, 2009 The stock fork spring is .61kg earlyer model evos were softer. Quote Link to comment Share on other sites More sharing options...
liviob Posted January 6, 2010 Report Share Posted January 6, 2010 These fellas made the rear spring. MCR 8106782617. They made me a front .71kg spring to match the heavy rear spring. With the .71kg i cannot dial in any preload because of where i have the rear spring preload set. I have to adjust firmess by adjusting oil height using Redline oil like water. I was able to get the suspension set to work very good but I recomend a .69kg if you weigh as much as me. If you are heavyer than me I will gladly trade you my .71kg for a .69kg as you will be very happy with my .71kg spring. After getting the spring preload adjusting screw to stop leaking fork oil. I did more testing and have found the .71 fork spring to work very well. I now have 1.25 turns of preload dialed into the spring. Scratch the .69 for a 250lb. rider. Quote Link to comment Share on other sites More sharing options...
benbeta23 Posted January 6, 2010 Report Share Posted January 6, 2010 SXS, Steve Saunders is expecting some stiffer fork springs coming in at the end of January. Quote Link to comment Share on other sites More sharing options...
