adywilson Posted December 19, 2009 Report Share Posted December 19, 2009 hi all is there any easy way of bleeding back brake ive had a go and managed to get a little effort but not enough to stop the bike any help would be much appreciated Quote Link to comment Share on other sites More sharing options...
tltel Posted December 19, 2009 Report Share Posted December 19, 2009 hi I had trouble with my sons gas gas and found the best way to bleed brakes and clutch was to use a large syringe filled with brake fluid, connect to bleed niple and gently force the fluid back up to the reservoir, you need to empty the reservoir first and make sure the bleed nipple is not blocked and is clean. hope this helps, it worked for me. TLTEL Quote Link to comment Share on other sites More sharing options...
adywilson Posted December 19, 2009 Author Report Share Posted December 19, 2009 thanks for the reply i will give it a try when i get to the garage next week thanks again ady Quote Link to comment Share on other sites More sharing options...
jse Posted December 19, 2009 Report Share Posted December 19, 2009 hi all is any easy way of bleeding back brake ive had a go and managed to get a little effort but not enough to stop the bike any help would be much appreciated usually the syringe works well but if you still have a little spongy feeling, you may need to get rid of the bubble that is often lodged inside the banjo fitting at the top of the master cylinder. Sometimes you can pressurize the system and then loosen the fitting a little to let the air out. If that does not work, you may have to take the M/C bolts off and rotate the M/C so that the reservoir inlet is above the outlet for the line, then you can pump the M/C piston a little to work the bubble up into the reservoir. Jon Quote Link to comment Share on other sites More sharing options...
adywilson Posted December 21, 2009 Author Report Share Posted December 21, 2009 thanks jon shall give a try on thursday and shall report on how ive done thanks again ady Quote Link to comment Share on other sites More sharing options...
adywilson Posted January 6, 2010 Author Report Share Posted January 6, 2010 had a go at bleeding brakes got all the air out but they dont work removed rear pads and checked for brake pistons moving but it looks like there well siezed does anyone have an idea where i can source a new calliper and master cylinder thanks ady Quote Link to comment Share on other sites More sharing options...
