davh Posted December 20, 2009 Report Share Posted December 20, 2009 I am looking for a 2nd hand four stroke?? I've owned a mont before and although the quality is obvious there expensive! I've been looking at sherco 3.2 they seem fairly resonable cost wise. I am looking to see if anyone has any experience of them, what to look out for etc etc most importantly are they reliable?? Is it worth spending the extra on a mont ?? Cheers in advance Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 20, 2009 Report Share Posted December 20, 2009 What level rider are you? The later model 3.2's are very snappy & better suited to experts. As far as reliablity goes the motor sounds to be pretty good, only real problems seemed to be hard starting on the earlier models. The rest of the bike apart from the frame is the same as the 2 strokes Quote Link to comment Share on other sites More sharing options...
copemech Posted December 21, 2009 Report Share Posted December 21, 2009 Apples and Oranges here! If you want better performance and light weight, go for the Sherco! Quote Link to comment Share on other sites More sharing options...
perce Posted December 21, 2009 Report Share Posted December 21, 2009 Apples and Oranges here! If you want better performance and light weight, go for the Sherco! clueless. Quote Link to comment Share on other sites More sharing options...
sherpa Posted December 21, 2009 Report Share Posted December 21, 2009 I have an 09 3.2 and I love it! 3.2 offers endless bottom end power, it will climb anything. Tony 27 is correct; the power does come on quickly so you have to learn throttle control. Also you will have to learn how it likes to be started. The handling is the same as the 2.9. The top end is a bit noisy if not properly shimmed and float level is critical. I enjoyed my two strokes but I don Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 21, 2009 Report Share Posted December 21, 2009 I have an 09 3.2 and I love it! 3.2 offers endless bottom end power, it will climb anything. Tony 27 is correct; the power does come on quickly so you have to learn throttle control. Also you will have to learn how it likes to be started. The handling is the same as the 2.9. The top end is a bit noisy if not properly shimmed and float level is critical. I enjoyed my two strokes but I don Quote Link to comment Share on other sites More sharing options...
copemech Posted December 22, 2009 Report Share Posted December 22, 2009 (edited) clueless. Ne sense of adventure, Puscifer! The damn things are fun to ride. Edited December 22, 2009 by copemech Quote Link to comment Share on other sites More sharing options...
perce Posted December 22, 2009 Report Share Posted December 22, 2009 Ne sense of adventure, Puscifer! The damn things are fun to ride. & heavy to push. Quote Link to comment Share on other sites More sharing options...
sherpa Posted December 22, 2009 Report Share Posted December 22, 2009 In warm weather she takes 2 kicks for the 1st start of the day, then one kick there after. In cold weather about six. I always allow about 5 mins warm up before riding. On the negative side; the motor does tend to flood easier than a two stroke. If the motor has been stalled while pointing down hill, the bike must be turned so that it is level to restart. I have not been able to restart my bike while pointing down hill after a stall. Turning the bike off does not cause an issue for restarting in any condition. I have been told that I can correct this issue with a float adjustment but just have not gotten around to trying it yet, it just doesn Quote Link to comment Share on other sites More sharing options...
bobtlr Posted December 22, 2009 Report Share Posted December 22, 2009 hey, i have been running a mont for 2 years and now on a sherco 3.2 build quality of the sherco is good, mine is a first kick starter ( i run an oko 24 mm carb now but it starts ok on the 28 mm keihin as wel) if my bike doesn't start after a fall and it looks flooded i start it on full trothle, works all the time i like the sherco a lot more than the mont, its a bit of a handfull for a novice/clubman but so is a raga, 2.9 sherco, .... only thing i dont like on the bike is the rear shock regards bob Quote Link to comment Share on other sites More sharing options...
