Clutch Arm Length
hewson
What gear oil are you running?My 240 clutch gets a reasonable level of effort when I run ATF in the trans,but it starts to shift stiffly after about 20 sections of a trial,I'm gonna try 50% atf and 50% 80 weight gear oil and see how well it does.ATF is about 5w and 80 weight is about 10w in motor oil equivalent in my unscientific tests. I am also going to experiment with the basic clutch engagement adjustment at the center of the clutch vs. the cable adjustment to see what the effects the internal cam position has on the feel of the clutch.
Hi
I'm running silkolene light gear oil , which i change every 5 trials ,i have a spare engine clutch arm which can be chopped and extended if anybody as more info ,i'm pretty sure this is the way to go for a
lighter clutch action ..... :biggrinsanta::thumbup:
My 300 Pro had an extended arm & it made a huge difference - with a short ' 2 finger' clutch lever you could feather the clutch with 1 finger in a section. I got it with the mod.
I no longer have the bike (stupid mistake - selling it!) so I cant measure it for you, but there was a clearance limit to what you could add. It took a bit of time to adjust as well because of the longer throw on the lever, otherwise it would slip. Also found a good well lubricated cable was critical.
Ian
  • 3 weeks later...
