thomastomsk Posted December 27, 2009 Report Share Posted December 27, 2009 i have a ty 175 and it has been standing in the garage for a couple of years,the bike was working fine when it was put away,but will not start now,,,,what is the best way to go about it,,,what to replace,,,etc. before i have a nother go at starting it.thanks tom Quote Link to comment Share on other sites More sharing options...
tony27 Posted December 27, 2009 Report Share Posted December 27, 2009 Strip & clean the carb as any fuel left in the float bowl will have evaporated & clogged the jets, is always a good start when trying to find reason for bike not starting Quote Link to comment Share on other sites More sharing options...
b40rt Posted December 27, 2009 Report Share Posted December 27, 2009 And also the petrol tap. Cant go wrong with a new plug. Check if your getting a spark. Quote Link to comment Share on other sites More sharing options...
stecks Posted December 27, 2009 Report Share Posted December 27, 2009 Not wanting to sound too obvious, but get rid of the old fuel and start with a fresh mixture. and Happy New Year Quote Link to comment Share on other sites More sharing options...
malcra Posted December 27, 2009 Report Share Posted December 27, 2009 As already said, my normal startup procedure for a bike that hasn't been run for a while : 1. As already said, fresh fuel, check the carb and remove clean the float bowl and get rid of the muck (if the bike has been stood > 1 year) 2. Check if there is a spark; change the plug, if no spark, check the connections, contacts, condensor etc 3, if there is a spark (and the plug is getting wet), then drop a small amount of fuel down the barrel and see if it fires (seems to work with DT Yamaha's in particular) 4. if it fires and dies, then its a fuel problem... 4a if it doesn't then its timing, lack of compression etc and more work required..... Quote Link to comment Share on other sites More sharing options...
thomastomsk Posted December 28, 2009 Author Report Share Posted December 28, 2009 thats brilliant .thanks for all the info,,,,,,cracking on with that now,,,,,,,,,,,,,,,,,,,,,, a happy new year to every,,,,hope you have a cracking 2010. Quote Link to comment Share on other sites More sharing options...
