goreboy Posted December 27, 2009 Report Share Posted December 27, 2009 Hi all, i`m very new at trials, my 95 jt25 is rubbing the silencer real bad, subframe doesnt seem bent, any suggestions ? would appreciate suggestions, not sure why it rubs as nothing looks wrong. Cheers Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted December 28, 2009 Report Share Posted December 28, 2009 Wheel in the dropouts straight? (same amount of adjustment on each chain snail adjuster) Wheel should run straight. Your wheel bearings okay? First two things to check Quote Link to comment Share on other sites More sharing options...
goreboy Posted December 30, 2009 Author Report Share Posted December 30, 2009 cheers for that, but wheel bearings are new, and wheel is running straight. Cheers Quote Link to comment Share on other sites More sharing options...
ham2 Posted December 30, 2009 Report Share Posted December 30, 2009 Swing arm bearings??? Space out the silencer top mount from the frame with some washers...sorry it's bit vague,been a while since I had a gasser. Quote Link to comment Share on other sites More sharing options...
jamez Posted December 31, 2009 Report Share Posted December 31, 2009 I have a jt 1994 gasgas and a jtr 1996 gasgas and both of them rub the exhaust :S now I bent abit the exhaust bracket abit out and its not bad now. Quote Link to comment Share on other sites More sharing options...
gasgasmi Posted December 31, 2009 Report Share Posted December 31, 2009 This is a problem with all the JTs I ever had. You can usually bend it out but I crash a lot and it always went back to rubbing. I had a patch welded on the inside of the silencer that I'm guessing was a bit thicker than the metal that the silencer is made of, still rubbed but never went through. I've seen guys rivet a patch on which allows for a quick change if it does wear out. Trick to that is getting it bent right so it doesn't reduce clearance. It was really nice when they went to the welded one piece exhaust ('07 I think?) haven't had it move a bit although I did have to space it out as it was rubbing right out of the crate. Quote Link to comment Share on other sites More sharing options...
