Pro Gear Oil
grib
What types of gear oil are people using in their Gas Gas Pros?
I have recently bought a 2003 250 Pro which has 2004 clutch plates in it, I am using Silkolene light gear oil (10w40) and the clutch is dragging. I have bled the clutch but it doesn't seem to have made any difference.
I use ATF in my 2004 and it works perfect. For what it's worth, I've run ATF in all my bikes for years...including MXers (where the loads are MUCH greater). It's perfect for clutches as that's what its designed for. If you are concerned about slippage, use the "Type F" intended for older Ford type trannys. It is designed specifically to prevent slippage.
