skippy1234 Posted March 2, 2010 Report Share Posted March 2, 2010 thanks Dan Quote Link to comment Share on other sites More sharing options...
dan williams Posted March 3, 2010 Author Report Share Posted March 3, 2010 Hi Copemech, Might take longer then I thought measuring springs. Hit a pot hole Monday and truck is in shop with exploded front end. Lucky I was doing 25 and not 65. Looked under to see bottom A arm laying on ground. Quote Link to comment Share on other sites More sharing options...
copemech Posted March 4, 2010 Report Share Posted March 4, 2010 Hi Copemech,Might take longer then I thought measuring springs. Hit a pot hole Monday and truck is in shop with exploded front end. Lucky I was doing 25 and not 65. Looked under to see bottom A arm laying on ground. Hehe! Quote Link to comment Share on other sites More sharing options...
mobbster Posted March 10, 2010 Report Share Posted March 10, 2010 Hi All My first post :-) so BIG hello... I have just carried out the clutch fix on my Beta Evo 250cc/2010 it really does make the clutch lighter to use ! Many Thanks for some great advice.... All the best. Cheers Quote Link to comment Share on other sites More sharing options...
skippy1234 Posted March 14, 2010 Report Share Posted March 14, 2010 just been out on me bike after doing the clutch fix its perfect now starts in gear nice and smooth really pleased thanks Quote Link to comment Share on other sites More sharing options...
rick1 Posted May 4, 2010 Report Share Posted May 4, 2010 Hey all, I completed the clutch mod and love the results, with one exception. I find there is a lot more clutch plate chatter. Have others who have done this mod found this to be true or did I miss something in the mod instructions? Quote Link to comment Share on other sites More sharing options...
dan williams Posted May 4, 2010 Author Report Share Posted May 4, 2010 There is more chatter. Don't worry about it. After a few weeks you won't even notice. It will also diminish a bit as the plates wear into their new configuration. Quote Link to comment Share on other sites More sharing options...
rick1 Posted May 4, 2010 Report Share Posted May 4, 2010 You da man Dan. I also switched to synthetic ATF, which I never used before, maybe that is part of the chatter issue as well. Quote Link to comment Share on other sites More sharing options...
scorpion Posted June 13, 2010 Report Share Posted June 13, 2010 For the easier clutch do you take out the 2 springs and the bolts, or remove the springs and put the bolts back in. And without trying to sound really thick does it matter which springs. Quote Link to comment Share on other sites More sharing options...
olec Posted June 15, 2010 Report Share Posted June 15, 2010 Holy crap! This mod really works! Let me say I didn't have so much believe in would fix my problem which actually is clutch slipping in 5th and 6th which is stated to be pretty "normal" for the Beta's (I have a rev3 270). The job was PITA and took me a couple of evenings, but it was all worth it. Clutch is both feelier and as I said, no more slipping. Thanks! I can't say I noticed any significant increase in the chatter either, but I am not so experienced. The bike vibrates and make so much chatter already so it can't get any worse I guess ;-) Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 18, 2010 Author Report Share Posted June 18, 2010 olec: Oh ye of little faith. scorpion: Yeah I just take the two bolts out. Why leave in something that can get loose and cause bad things to happen? Quote Link to comment Share on other sites More sharing options...
crash Posted June 19, 2010 Report Share Posted June 19, 2010 I ride a 2008 4t would this mod benefit me, clutch sticks from cold but i have already removed 2 springs so it's nice and light Quote Link to comment Share on other sites More sharing options...
ham2 Posted June 19, 2010 Report Share Posted June 19, 2010 I ride a 2008 4t would this mod benefit me, clutch sticks from cold but i have already removed 2 springs so it's nice and light Tut,Tut..Mr. Crash, Are you aware that the 4RT owners club has strict rules when it comes to tweaking your Montesa? You are expected to throw a lot of wonga 1 Quote Link to comment Share on other sites More sharing options...
nzralphy Posted June 19, 2010 Report Share Posted June 19, 2010 Hi All. I got some clutch slip yesterday up some long big hills. I guess the 4 spring idea was a little hopeful. I have gone back to 6 springs and will test today. Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 20, 2010 Author Report Share Posted June 20, 2010 (edited) From what was said earlier about the 4T clutch pull it's entirely possible it uses lighter clutch springs anyway. Hmmm according to the engine manuals for the 08 2T and 4T same part number (13.5kg spring) EDIT I think this should be 13.5 N/mm] Could be affected by fluid type or the adjustment bring a bit too tight or it could really just be slipping. Edited February 22, 2013 by dan williams Quote Link to comment Share on other sites More sharing options...
