The Beta Clutch Fix
dan williams
TLTEL,
Sweet, as long as it works. I was just curious.
Pete,
The thicker first and last plates come standard on the 2013. Beta sold them before as a special. They increase the preload on the springs by making the clutch pack a little thicker. All plates the same is a clutch pack from the previous years. The same thing I have put in my bike. I like the older pack better. It has a much more progressive take up than the new pack. I think you'll really like it unless you are an uber expert.
I'm no uber expert I'm afraid! I'll let you know how I get on.. Incidentally, do you run your bike with a flywheel weight added, we have them as standard here in the uk, might try it without just to see if there's any noticeable difference.
Getting ready to do the modification on my 2011 Beta. Before I invest the time and energy, trying to decide if I should by new plates first and do the mod on them rather than the old ones. So, the question is: How do I know if my old plates need replaced? Is there a minimum thickness they should be?
Thanks
Unless you are an expert and do a lot of full throttle splats my guess is your current plates are fine and you can just do the mod on them. Over time the steel plates can get polished to the point of slippage and a quick dressing with super fine grit emory cloth will bring them back to normal.
Hi Dan, I've completed a full trial with the modified plates now and it's much much better, no drag or slip, well worth doing, very pleased. I bought new plates and spent a lot of time rubbing away the glue from I between the pads and smoothing off the tabs. The clutch is now progressive and smooth. I'd recommend the mod to anyone. Also I much prefer the power delivery without the flywheel weight, less over run on slow sections and more instant but still controllable power delivery when you need it. Thanks!
Hi Dan, I'm not aware of the stepped washers/spring retainers, it's not something I've changed.
I went out again today and the clutch was great. The only thing was a rattle from the plates that I could hear from time to time, but in think I've read that they do that after the fix?
Hi Pete, on my '13 300 the retaining washers are anodized red stepped washers that you can either mount with the flat side towards the spring or with the stepped side towards the spring reducing the preload on the springs 2~3mm.
Come to think of it those washers would probably retrofit a Rev3.
Oh yeah, the plates rattle a bit more until they settle in. Don't worry, you won't even notice it after a while.
Edited by dan williams
  • 1 month later...
hello , I have a question about the clutch . my evo 290 2010 is slippery on 5 and 6 gear so I changed the plates , springs and metal plates and do the same.
before the change I test 3 different oils and do the ''dan work" .......
any ideas?
Make sure you don't have the lever adjusted in too far. At the rest position for the lever the piston in the master cylinder should be all the way out resting on the circlip. It's common for people to adjust the lever such that the piston doesn't return all the way so it never uncovers the resevoir. What happens in that case is the system is closed so it never equalizes fluid pressure that builds up as the fluid heats causing the clutch (or brake) to be partially on. With the clutch it's like feathering the lever. The reason a clutch slips first in the higher gears is because the load on the engine is much greater. On a trials bike the top gears are loop gears and spaced much further apart than the lower 3-4 gears.
Dear Dan,
Thank you for being patient and writing me about my problem.
I really didn't write about my problem on the forum without reading first the previous 11 pages related to the Beta clutch.
So, I followed all the possible solutions described and only when I was desperate I wrote the question.
The lever clutch has a gap (the piston is free).
When I put the disks I checked the gap that should have in the center of the clutch. It almost had NO gap at all.
I tested the bike and do the same.
After, I reopened the clutch and I took out one, the thinnest, of the two washers that are on the bearing.
When I tied the clutch, it had a gap. I tested the bike and it was improved on the 5th gear (not completely disappeared) but it is doing the same on the 6th gear.
DESPAIR!!
Should I check the clutch pump? (on the carter)
Is there any risk now that the clutch has only the one washer inside?
