The Beta Clutch Fix
Not sure what difference this may make but just adding to the general knowledge I notice the Beta fiber plates are now noted as being Ferodo rather than Adige. I personally haven't seen any but I do see Beta wants a lot more money per plate.
  • Replies 482
  • Views 319.3k
Most Popular Posts
  • You bet!
  • markparrish
    markparrish
    Having only recently embarked on my trials experience I have been so pleased to have found the great advice and support on this forum. I thought you might be interested to see my clutch mod based on s
  • dan williams
    dan williams
    Your oil is roughly the same as 15wt motor oil according to the charts I can find so nothing odd there. It sounds to me as if your clutch is operating properly but you could try adjusting the set scre
I noticed some of the bikes that use the 3mm Barnet plates also call out 1 plate with a different number. I ordered one just to see if it’s the same form factor with a different thickness. I’ll let you all know what I find.
Interesting the plate is still 3mm thick but the friction material is semi-metallic and the plate width is thinner. Something I didn’t notice about the kevlar plates is they are slightly wider than the stock plates.🤔
