Ty250 Stem Bearings Upgrade
searay175
Gday, they are an unusual (non ISO) size. Go with the Feetups' previous post - see your local bike shop. The TY's use a very common Yamaha neck bearing set, readily available and the only way to go. I like All-Balls kits as they come with all the necessary seals as well.
Cheers,
Stork
Searay,
My guess is you are correct, they probably are an "off the shelf" item. Take a set of calipers to one and check the Timken or other bearing site. If I remember correctly we found that the main bearings and seals where stock items.
Alan
