Fork Oil Quantity
manwithtool
I'm a bit confused, How much oil do I put in my sons 2008 125 ? According to MRS technical info a 125 has 330cc in each leg. But if you look accross the page it seems to give the year....So 06-09 it's 385 LH and 370 RH fork leg......I guess I'm going with the 385 and 370. Bit confusing though ? or is it me ?
Cheers
330 per leg any more just f***s them up
Actually they will work just fine, although it is imparitive that you grt all the old oil out! In a nutshell this means removing the dampening unit and manually working it back and forth for some period of time maybe up to five minutes or so. Seems anything less is just a guessing game.
I seemed to have difficulty getting an accurate read using the levels method, not quite sure why? B)
