manwithtool Posted December 31, 2009 Report Share Posted December 31, 2009 I'm a bit confused, How much oil do I put in my sons 2008 125 ? According to MRS technical info a 125 has 330cc in each leg. But if you look accross the page it seems to give the year....So 06-09 it's 385 LH and 370 RH fork leg......I guess I'm going with the 385 and 370. Bit confusing though ? or is it me ? Cheers Quote Link to comment Share on other sites More sharing options...
ishy Posted December 31, 2009 Report Share Posted December 31, 2009 Up to 2005 was 330 / leg 2006 and on is 385 Lft leg and 370 right, make sure you have all the oil out. Quote Link to comment Share on other sites More sharing options...
manwithtool Posted December 31, 2009 Author Report Share Posted December 31, 2009 Cheers, Forks have been stripped down to fit new seals.....hate this job !! Thanks again... Quote Link to comment Share on other sites More sharing options...
1sherco1 Posted December 31, 2009 Report Share Posted December 31, 2009 330 per leg any more just f***s them up Quote Link to comment Share on other sites More sharing options...
copemech Posted January 1, 2010 Report Share Posted January 1, 2010 330 per leg any more just f***s them up Actually they will work just fine, although it is imparitive that you grt all the old oil out! In a nutshell this means removing the dampening unit and manually working it back and forth for some period of time maybe up to five minutes or so. Seems anything less is just a guessing game. I seemed to have difficulty getting an accurate read using the levels method, not quite sure why? Quote Link to comment Share on other sites More sharing options...
