Tubeless Tyre
scorpa250
hello all, does any of you twinshokers out there run a tubeless michelin (with a tube) on the rear ?? i remember a few years ago i had a irc tubeless on the rear of a fantic and when you let the air out to 5psi it would break the bead and look like the wheel was buckled .i only ask as i have a new michelin in stock and my beamish needs a tyre. Thanks Paul.
Paul it depends on which tubeless tyre and which tube type rim. At low pressures, Dunlop tubeless rears wont stay in place on any tube type rim while Michelin XII tubeless and IRC tubeless will stay on some tube type rims but not others. Sorry I've not tried any tubeless tyres on Suzuki rims.
Pete I suspect you might have had problems if you ran trials pressure in your DRZ400 rear
David
