Cota 247cc Assembly Of The Crank And Main Bearings.
bridgwaterjohn
I have stripped down the bottom end, to replace the main bearings and seals. I am looking for advice in which order to reassemble the crank and main bearings. Do you heat the two halves of the casing and fit the main bearings into the casing first and the fit the crank ? If so how do you know the position the bearings in the casing as there is no lip to push them up against.
