foulkesy Posted January 3, 2010 Report Share Posted January 3, 2010 Help!!The temp Sender is hidden somewhere else,and the fan has not kicked in so need to check..Unlike the newer models which are easy to find.Any advise please and or diagrams for this model.Its the one with upside down forks. Quote Link to comment Share on other sites More sharing options...
stork955 Posted January 3, 2010 Report Share Posted January 3, 2010 Gday, with upside down forks it must be a Techno? Are you sure of the year? You can check all of this on the Beta UK website, you need to know your frame number. It will help if we can work out which bike you actually have first. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
foulkesy Posted January 3, 2010 Author Report Share Posted January 3, 2010 Stork955 said: Gday, with upside down forks it must be a Techno? Are you sure of the year? You can check all of this on the Beta UK website, you need to know your frame number. It will help if we can work out which bike you actually have first. Cheers, Stork Hi it is a Techno, looking at the Beta web site the upside down forks were only in for 2000 (that good eh)Thanks for reply any info greatly appreciated Quote Link to comment Share on other sites More sharing options...
trialsnutterman Posted January 3, 2010 Report Share Posted January 3, 2010 Don't know if it was different where your from but the first Rev3 definitely came with the upside down forks. I'm not sure were the thermo is but it will be on the rad somewhere can you not drop it out of the fram a little to see. Quote Link to comment Share on other sites More sharing options...
foulkesy Posted January 3, 2010 Author Report Share Posted January 3, 2010 Do not know if its a European thing, everything indicates a Y2K Rev 3. Techno was a 1999 and conventinal forks different colours to mine.Mine is red front guard, Black rear Quote Link to comment Share on other sites More sharing options...
lineaway Posted January 4, 2010 Report Share Posted January 4, 2010 The filler cap is under the black plastic frame cover on the left side, the one with the B. The early model rev 3`s had the sending unit somewhere towards the top of the radiator. Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 4, 2010 Report Share Posted January 4, 2010 2000 was first year of the Rev3. Had upside down forks. Temp sending unit is on the radiator somewhere I just don't remember exact position. Same sending unit though so just look for big brass nut on radiator with wires coming out of it. Quote Link to comment Share on other sites More sharing options...
stork955 Posted January 4, 2010 Report Share Posted January 4, 2010 Gday, on the parts list it looks like the top L/H side of the radiator. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
matt_urban Posted January 4, 2010 Report Share Posted January 4, 2010 i had a 99 techno it was red and silver with dark grey front mud flap sensor was on the head i now have a 2005 rev 3 and its at the bottom of rad . to fill the rev 3 you remove the right (as your looking at the bike from the front) black plug on the frame near the headtube if its a techno the rad has a cap to fill it this may help http://www.trialsport.com.au/beta/documents.htm http://www.bcdirtbikes.com/Everything-Else...hno-Manual.html Quote Link to comment Share on other sites More sharing options...
matt_urban Posted January 4, 2010 Report Share Posted January 4, 2010 sounds like yours is a 2000 rev 3 Quote Link to comment Share on other sites More sharing options...
betabonkers Posted January 4, 2010 Report Share Posted January 4, 2010 Its on top somewhere for sure my mate had 1. Quote Link to comment Share on other sites More sharing options...
foulkesy Posted January 5, 2010 Author Report Share Posted January 5, 2010 matt_urban said: sounds like yours is a 2000 rev 3 I think I have now established its a 200 rev 3. Having always Enduro or Scramblers and liitle experience of Trials bikes. How did this model rate ? Quote Link to comment Share on other sites More sharing options...
matt_urban Posted January 5, 2010 Report Share Posted January 5, 2010 i think most of it is the same as my 2005 they have just tweeked it a bit so cant be to bad Quote Link to comment Share on other sites More sharing options...
foulkesy Posted January 5, 2010 Author Report Share Posted January 5, 2010 Thanks for the replies troops, found the Critter, bit of a pain to get at compared to the newer Rev 3's. No doub't I will have more questions for you all SOON. Regards Dave Quote Link to comment Share on other sites More sharing options...
bazza Posted May 6, 2010 Report Share Posted May 6, 2010 foulkesy said: Thanks for the replies troops, found the Critter, bit of a pain to get at compared to the newer Rev 3's. No doub't I will have more questions for you all SOON. Regards Dave Hi Foulkesy, how did you get to the sender, did you need to remove the radiator completly or did you find a different way as i was stumped last night, i found it ok right at the top in the middle but had problems trying to remove the radiator. Thanks Barry Quote Link to comment Share on other sites More sharing options...
