squid Posted January 9, 2010 Report Share Posted January 9, 2010 Hello again. About a month ago I had a problem with me carb on a ty 125. The float was blocked thus flooding me engine. Thanks to various people on this site alls working dandy now. Its just the first time I took it out I had this muck dribbling out the exhaust. I assummed it was just excess fuel passing through the system. Anyway I've taken the exhaust off to decoke and there was quite alot of this treacle. Please tell me its not me autolube system needs tinkering with as I've looked at me manuel and it looks a bit beyond me. Cheers Squid. Quote Link to comment Share on other sites More sharing options...
dave dix Posted January 9, 2010 Report Share Posted January 9, 2010 That thick black treacle is un-burnt oil so its over-lubing the barrel. Either re-adjust the autolube or blank it off and mix in the tank and use a good oil or a fully synthetic one that will burn off better thou they all leave some unburnt oil behind Dave Quote Link to comment Share on other sites More sharing options...
andy m Posted January 9, 2010 Report Share Posted January 9, 2010 Yamaha pumps have small shims to adjust them.There is/was a special tool to sort them. Many were set rich back in the day. Your best bet would be remove it altogether and use premix, you can run a leaner mix nowadays compared to when your bike was new as oils have moved on big time. Someone else will need to advise on the mix. Quote Link to comment Share on other sites More sharing options...
squid Posted January 9, 2010 Author Report Share Posted January 9, 2010 Thanks for those snippets much appreciated. Quote Link to comment Share on other sites More sharing options...
nzralphy Posted January 9, 2010 Report Share Posted January 9, 2010 Slosh 500ml of petrol around the disassembled exhaust to get the goop out. Let it stand before using..... to let excess evaporate. Quote Link to comment Share on other sites More sharing options...
squid Posted January 10, 2010 Author Report Share Posted January 10, 2010 Cheers NZRalphy. Squid. Quote Link to comment Share on other sites More sharing options...
mattylad Posted January 12, 2010 Report Share Posted January 12, 2010 You could also put the entire system on the BBQ or a fire and heat it to burn out the gunk! Quote Link to comment Share on other sites More sharing options...
kev99 Posted January 12, 2010 Report Share Posted January 12, 2010 hi all , 40-1 mix works well on both 175 and 250 ..kev Quote Link to comment Share on other sites More sharing options...
squid Posted January 12, 2010 Author Report Share Posted January 12, 2010 Hello Kev99 Mines still a squirty little 125. Cheers Squid. Quote Link to comment Share on other sites More sharing options...
kev99 Posted January 12, 2010 Report Share Posted January 12, 2010 hi squid , cant see no reason that the 125 would not be ok on 40:1 mix but i can be corrected if wrong guys Quote Link to comment Share on other sites More sharing options...
