godzilla Posted January 13, 2010 Report Share Posted January 13, 2010 Im putting a full topend on my 315 (re-nicosil piston ect ect ect) and i have been given conflicting info about ring gapping by two well respected trials mechanics. one says no need to gap the rings as the tolerances are so fine, and the other say they need gapping to stop the piston nipping, i am undecidad any info or advice would be good thanks. I didnt bother gapping my she-co and it was totaly fine. Quote Link to comment Share on other sites More sharing options...
betarick Posted January 13, 2010 Report Share Posted January 13, 2010 no need to gap rings your barrel will of been replated and then bored to orginal size! so just bang piston back in being carefull to locate them correctly on piston! Quote Link to comment Share on other sites More sharing options...
tonybroad Posted January 13, 2010 Report Share Posted January 13, 2010 at least check there is some gap before fitting, don't assume anything tony Quote Link to comment Share on other sites More sharing options...
stork955 Posted January 13, 2010 Report Share Posted January 13, 2010 Gday, as Tony said, check first. Pop the rings (one by one) into the bore and square them using the top of the piston. Keep them away from the ports to prevent damage. Dont use any force. You should have roughly 4 thou per inch of bore (0.1 mm per 25 mm of bore), a bit more is not a problem. You should check this every time you are fitting rings to anything. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
godzilla Posted January 14, 2010 Author Report Share Posted January 14, 2010 Thanks guys, that was what i had intended to do. Quote Link to comment Share on other sites More sharing options...
