simmsy Posted January 14, 2010 Report Share Posted January 14, 2010 Hi all, I have just bought some new Tank decals and do not have a clue how to attach them to tank. I have peeled off one side of the center tank sticker for a butchers but it does not seem sticky enough to attach to the tank. Some advice would be appriciated before I mess them up and have to buy a new set. Thanks Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted January 14, 2010 Report Share Posted January 14, 2010 (edited) Hi all,I have just bought some new Tank decals and do not have a clue how to attach them to tank. I have peeled off one side of the center tank sticker for a butchers but it does not seem sticky enough to attach to the tank. Some advice would be appriciated before I mess them up and have to buy a new set. Thanks Warm them up, if they're cold they will be hardly sticky atall, use a hairdryer, and warm them right up so they're soft! Apply, then keep the heat on them for a minute, then cool them down slowly... can do this by filling your tank with boiling water. Make sure to clean the are thoroughly! Edited January 15, 2010 by shercoman2k8 Quote Link to comment Share on other sites More sharing options...
crash Posted January 14, 2010 Report Share Posted January 14, 2010 (edited) wash the tank thoroughly ensure there is no grease, spray a light mist of soapy water onto the tank this will enable you to get it in the correct place, use a clean rag and push from the center out to the edges ensuring to remove all air bubbles, warm with a hairdryer and get pressing down, best done in a warm and damp free environment, will stick like "sh*t to a blanket" Edited January 14, 2010 by crash Quote Link to comment Share on other sites More sharing options...
simmsy Posted January 14, 2010 Author Report Share Posted January 14, 2010 wash the tank thoroughly ensure there is no grease, spray a light mist of soapy water onto the tank this will enable you to get it in the correct place, use a clean rag and push from the center out to the edges ensuring to remove all air bubbles, warm with a hairdryer and get pressing down, best done in a warm and damp free environment, will stick like "sh*t to a blanket" Thanks Crash will try tomorrow. Quote Link to comment Share on other sites More sharing options...
