old trials fanatic Posted January 23, 2010 Report Share Posted January 23, 2010 Hi need to replace the chain and sprockets on the James. Now it's been running on a 428 chain but i've seen some on a 520. Same with cubs now most people seem to run a 420 on the cub but it seems a bit light duty to me. So what does the panel think about chain sizes? i know sprockets are a personal choice but i was wondering what people are fitting to their Pre65 bikes. twinshock is easy as most of the factory details are pretty good anyway so stick with them but the Pre65 bikes are all so modified nowadays i was just wondering what you have fitted to your Cub, C15, B40, James, Bantam etc etc etc Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 23, 2010 Report Share Posted January 23, 2010 B40 - 428 buy it cheap and replace it often. (tried more expensive chains, gone back to replacing as sprockets last longer. Important when you know what's involved in changing the gear box sprocket) Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted January 24, 2010 Report Share Posted January 24, 2010 Hi Guy's Hi OTF. Well you know what they say a 520 lasts a lot longer, but is heavier, 428 seems like a compromise, But then look what the Norton's ran. so it is a job to choose I would stick with what you are running at present. Just ring Amanda for a good deal. Regards Charlie. Quote Link to comment Share on other sites More sharing options...
gii Posted January 25, 2010 Report Share Posted January 25, 2010 246cc Cub runs with a 520 chain but it's a bit tight between the clutch and gearbox - wears away the split link, must get round to fitting a rivet type. Also, now Serco have gone I'm not too sure where I could get a new front sprocket. Anyone know who made them for Serco? Quote Link to comment Share on other sites More sharing options...
trialsoldtimer Posted January 26, 2010 Report Share Posted January 26, 2010 Hi GII Talon Engineering made them for Martyn Quote Link to comment Share on other sites More sharing options...
trialsoldtimer Posted January 26, 2010 Report Share Posted January 26, 2010 Hi GII Here is my amended reply Talon Engineering made them for Serco but they required a separate spacer. I got him to order some 520 sprockets to the same dimensions as a standard cub one - don`t know if Talon still do them. Quote Link to comment Share on other sites More sharing options...
gii Posted January 29, 2010 Report Share Posted January 29, 2010 Thanks, I've always found Talon to be very helpful but was rather concerned to see the statement on trialsbits website that whilst they stock Talon rear sprockets for Cubs in 520 size, fronts are unavailable Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted January 30, 2010 Author Report Share Posted January 30, 2010 Thanks,I've always found Talon to be very helpful but was rather concerned to see the statement on trialsbits website that whilst they stock Talon rear sprockets for Cubs in 520 size, fronts are unavailable FWIW i have always found Talon also most helpful in the past but i am now having serious missgivings about them. Not only are they now unable to supply 520 front sprockets for the cubs they now refuse to supply ANY gearbox sprockets for ANY of the Villiers engines. They now state "we are no longer supplying any villiers sprockets directly to customers trade or retail. For ALL Villiers sprockets you must now buy them through Villiers Services!" Will i ????? err no i wont. Think Talon are in the process of losing the plot guys Quote Link to comment Share on other sites More sharing options...
mickmetcalfe Posted February 2, 2010 Report Share Posted February 2, 2010 The Talon statement probably means that they have done a 'sole supply' deal with Villiers Services and Im guessing it is because Villiers sprockets are low volume quantities compared with other markets and it makes commercial sense to make one big batch rather than several small and irregular ones. I'm sure Talon would do the same thing for the Cub if someone commits to a good sized order. I personally dont see what the problem is buying from Villiers Services. I've been using them for many years without any problem whatsoever. Quote Link to comment Share on other sites More sharing options...
totalshell Posted February 2, 2010 Report Share Posted February 2, 2010 Damn nice chap At villiers services sorted my ignition out over the phone whilst he was having his tea! having said that somebody there needs a bit of cadjoling to get the info from. none the less they know there stuff and have the stock cant ask for more.. Quote Link to comment Share on other sites More sharing options...
