Bultaco 325 1975
millerme
Sorry for the delay in getting the info. I had surgery last friday and am off work for at least a week so I should be able to help you with getting the dimensions you need.
It sounds you are looking for a tank mount to swing arm pivot dimension. I get 692mm
Swingarm itsself has two tubes which the pivot bolt passes through. They measure 70mm (around 3"). They are fitted with grease fittings. The pivot also passes through the triangular rear engine mount.
I've uploaded a bunch of pictures during the diassembly of the bike. Maybe this will help you in finding what you are looking for.
http://s259.photobucket.com/albums/hh316/z...erpa%20T%20350/
Let me know if there is anything else specific you are looking for.
Matt
