simmsy Posted January 25, 2010 Report Share Posted January 25, 2010 With the clutch plates removed for inspection and cleaning I pulled trhe clutch lever by accident while moving the bike. Now it seems that I do not have any clutch, what do I need to do to rectify this problem once I find the bloody ball bearing that fell out and rolled away. Thanks Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 25, 2010 Report Share Posted January 25, 2010 (edited) Apparently you didn't wedge it in place with cheese like I told you. All that stuff you went through with the brakes as far as bleeding and chasing bubbles. You now have to do the same after reassembling the clutch. You may be chasing bubbles for a while. Patience is required since it sometimes takes a while for trapped air to work its way to the top. You can back-bleed to speed up the process but to completely clear the system takes time. Good luck. Edited January 30, 2010 by Dan Williams Quote Link to comment Share on other sites More sharing options...
