44wilky44 Posted January 26, 2010 Report Share Posted January 26, 2010 anyone got any tips on getting the flywheel nut off (any home made tool tips ) thanks lee Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 26, 2010 Report Share Posted January 26, 2010 compresser and ratchet gun easy or flywheel holding tool and socket still not hard you dont need screwdrivers, wooden wedges or hammers. if you think you do, yer doin wrong! also lee Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted January 26, 2010 Author Report Share Posted January 26, 2010 (edited) was thinking of useing rachet tye downs rapped round the flywheel and foot peg for support can you use the rachet gun without a holding tool Edited January 26, 2010 by 44wilky44 Quote Link to comment Share on other sites More sharing options...
marky g Posted January 26, 2010 Report Share Posted January 26, 2010 Air rachet is the preffered way but if you have not got access to comp air I've always found that a socket and a T bar will do, a few short sharp hits to the end of the T bar normally does the trick (don't hit the flywheel though!!) Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 26, 2010 Report Share Posted January 26, 2010 was thinking of useing rachet tye downs rapped round the flywheel and foot peg for supportcan you use the rachet gun without a holding tool A ratchet strap wound 2/3 times roumd the flywheel (so it over laps) and the free end clamped to the foot peg with a vice grip will do the job, even with a ratchet and socket. As you turn the socket the strap will tighten more than enough to stop the flywheel turning. (You just have to wind the strap on the right way) Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted January 26, 2010 Author Report Share Posted January 26, 2010 cheers sounds a better way ill give it a go thanks lee Quote Link to comment Share on other sites More sharing options...
nicbrrghs Posted January 27, 2010 Report Share Posted January 27, 2010 Try using a 12v Impact driver like the ones used to removal car wheels. These are a nice tool and prove useful Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 27, 2010 Report Share Posted January 27, 2010 I'm not familiar with the Montesa but this is what I made for a Beta. Couple pieces of bar stock, some screws and washers and handled 100ft/lbs no problem. Cost about $6. No slippage and plenty of leverage. Just be careful the bolts don't go through the flywheel into the coils. Aluminum washers help keep the spacing correct. Quote Link to comment Share on other sites More sharing options...
44wilky44 Posted January 27, 2010 Author Report Share Posted January 27, 2010 the montesas flywheel has no places to put nuts and bolts (looks like a good tool like) just removed the nut with the rachet strap and my woodruff key is still in when i grab hold of my flywheel and give it a good rock i can fell a slight movement dose this mean my bottom end bearings have gone thank lee Quote Link to comment Share on other sites More sharing options...
