Tlr200 Rear Wheel/ Sprocket Bushes?
mcman56
Are the 4 bushes that engage the rear wheel and sprocket still available somewhere? (Bikebandit shows them as obsolete.) Or...is there another option? I have heard of filling the area with weld to tap for studs but I'm no great aluminum welder. Has anyone tried press fitting solid metal bushes? Thanks!
Hi These bushes are listed as in stock at www.cmsnl.com for 6.5 euros each, I have ordered lots of stuff for my TL125 (like front and rear tank rubbers that you cant get any where else) from here and the servive is excellent. When you order you can change the amount into pounds so you know what you are paying.
Hope this helps.
Just somthing to bear in mind I thought I was being clever about 20 years ago by fitting solid bushes in my TL wheel, that was untill; the hub shatered, so the rubber is there for a good reason.
Good luck.
TLTEL
